-   Engine & Internal (https://camaroforums.com/forum/engine-internal-23/)
-   -   LS7???? (https://camaroforums.com/forum/engine-internal-23/ls7-33054/)
psycho209 Nov 14, 2008 09:04 PM
LS7????
Would an LS7 fit a 93-96 or a 97-02 camaro?:eek: I think that would be a really awsome thing to do if it fits put a z06 engine on a camaro. ;)
How about an LS2? I know its not as strong but would it fit?
95slvrZ28 Nov 16, 2008 01:11 PM
RE: LS7????
They have the same external dimensions. They're based off the same size block as an LS1, although they're not identical. I believe the heads on the LS2/LS7 are taller than that of an LS1, so you my run into some clearance issues. Needless to say, the swap isn't going to be a cheap or easy job, you're going to need to get a full LS1 donor car and more if you're trying to put in an LS7. Good luck...
