LS7????
They have the same external dimensions. They're based off the same size block as an LS1, although they're not identical. I believe the heads on the LS2/LS7 are taller than that of an LS1, so you my run into some clearance issues. Needless to say, the swap isn't going to be a cheap or easy job, you're going to need to get a full LS1 donor car and more if you're trying to put in an LS7. Good luck...
I think that would be a really awsome thing to do if it fits put a z06 engine on a camaro.
