ignition control
ignition control
Got another question, cant seem to find relevant threads anywhere here.......
Id like to add an ignition controller to my new zz4 350 in my 70 camaro, have been trying to decide what is the best way to go.
It has a standard GM HEI distributor which came with the engine, with an internal coil. Should I change it out with just something like an ACCEL Brute thunder coil/cap or MSD Super HEI kit and use an external coil? can I wire a MSD 6 series controller to my existing distrib. with just a GM harness? Do I need to change spark plugs?
Thanks in advance for any help.
