Engine Upgrade
RE: Engine Upgrade
The easiet way to go is just to put a like a 350 in it, usually the the frame is already drilled and all you have to do is reposition the mounts, just line it up when you are about to put the new motor in, instead of buying a new car, thats probably the easiest way to go, if I were you, I wouldn't buy an lt1 because they can be pretty expensive to fix, just rely on the old classic small block chevy.
lonso916
08-25-2007 10:42 PM
