Engine Identification
Old Apr 2, 2010 | 11:18 PM
JumboNuttes's Avatar
Default Engine Identification
Its a GM 350 small block numbers on block are 16s436522 V0521ckx.
Old Apr 2, 2010 | 11:47 PM
Mtowles's Avatar
here try this http://www.nastyz28.com/sbchevy/sblock.php
Old Apr 3, 2010 | 12:13 PM
blackz87's Avatar
No such casting numbers on Mortec.com for Chevy 350.
Old Apr 3, 2010 | 08:35 PM
^ Of course those numbers don't show up there, those aren't casting numbers. The first set of numbers is his partial VIN.
The second set of numbers decodes as:
V - Flint Michigan engine plant
05 - Month (May)
21 - day of the week (21st)
CKX - either a 1972 200 h.p. 350, or a 1973 145 h.p. 350, or a 1976 180 h.p. 350.
The casting date on the bellhousing flange will tell which one he has.
Old Apr 4, 2010 | 09:15 PM
found on the net 1972 Corvette engine. not 100% sure.... On the back of the engine 6GM and 3970010 and E46 , and it has an iron manifold with EGR .Need to know so I can buy a gasket kit and other parts
Old Apr 5, 2010 | 01:58 AM
Casting date codes go from A-L (representing January to December)
E46 = May 4, 1976
That also corresponds with your build date 17 days later.
Old Apr 5, 2010 | 06:10 AM
but that's all the numbers I found on the engine. anything else I can do?
Old Apr 5, 2010 | 06:43 AM
blackz87's Avatar
Now those are the Chevy casting numbers for 1969/1980 350 block.
Old Apr 5, 2010 | 09:11 AM
What else you want to know, what it came out of?
It's a 1976 L48 350, 180 h.p., out of a Vette, and was coupled to an automatic trans.
Dreamcatcher
Oct 25, 2012 01:04 AM
mrsurfs
67-69 V8 Tech
25
Apr 16, 2012 06:35 PM
hardtail
70-81 V8 Tech
Oct 12, 2009 06:45 AM
cody69
Mar 13, 2009 12:24 AM
