A Cam on TPI
Old Feb 21, 2007 | 02:21 AM
White Zombie's Avatar
Default A Cam on TPI
i found this great cam from compcams but it says need an aftermarket chip,ok but i didnt find any chips for my car,its a 1992 camaro TPI and why the hell my car needs a chip?my ECU is not that stupid loool,ok here is the spec of the cam
"XFI" 292 Hydraulic Roller Camshaft
GM 305-350ci 1987-98
Lift: .584"/.579" w/1.6 Rockers
Duration: 292°/300°
RPM Range: 2200-6200
249-08-468-8
Good mid-range with excellent top end. Will require headers, gears and 2500+ stall. Rough idle.
Note: for use with 1987-98 305 & 350ci factory hydraulic roller camshaft applications, EXCEPT LT1 & LT4.
Operating Range: 2200-6200 RPM
Duration Advertised: 292° Intake / 300° Exhaust
Duration @ .050' Lift: 242° Intake / 248° Exhaust
Valve Lift w/1.6 Rockers: .584' Intake / .579' Exhaust
Lobe Separation Angle: 113°
in summitracing.com it says need an aftermarket chip so where can i find this chip?
Old Feb 21, 2007 | 02:25 AM
Default RE: A Cam on TPI
oh and i forgot do i need to upgrade my valvetrain?from springs to locks?because i dont want to open the heads
Old Feb 21, 2007 | 10:36 AM
blackz87's Avatar
Wow, you call that a great Cam for a stock TPI?? Good luck...Your knowledge of Cams & ECU are in question.[sm=smiley25.gif][sm=smiley25.gif][sm=smiley25.gif]
Old Feb 21, 2007 | 05:55 PM
i wont install it now on my stock engine,i was asking is it a great cam for TPI and yeah its my fault i didnt tell u guys i need this cam after heads and intake manifolds upgrade,the heads i got in my mind are Sportsman II and the intake manifold from edelbroke a whole package but i think no one wants to help me because im a new member so thnx anyway
Old Feb 22, 2007 | 04:07 PM
Whenever you put ina new cam you should be using matching springs to avoid valve bounce and valve float. Both are good ways to destroy performance and the new cam. If it is a flat lifter cam you also need new lifters. If the car uses a MAF sensor you may be able to get away without a computer tune. If the car uses a MAP sensor only you will need a ECM tune if you expect to get the best results.
