Built 327, which plugs to use ?
Old Nov 8, 2009 | 01:30 PM
Houndog101's Avatar
Default Built 327, which plugs to use ?
Working on a 71 camaro with a built 327. It has Accel 576s plugs in it now, What plug (NGK, etc.) would go good and what heat range to start with ? Motor has aftermarket cast iron heads that have "Pro" stamped on them. Thats all we know about the motor. Thanks, John
Old Nov 8, 2009 | 06:28 PM
Besides the plug size, which must be accurate, a lot depends on how the engine was built. Compression, cam, and RPM range will dictate the proper heat range. Learn how to read the plugs and that will give you a starting point.
hoursetraitor
Apr 25, 2011 10:14 PM
Posi
Apr 27, 2009 01:50 AM
Lookingformydadscar
Dec 15, 2008 06:31 PM
Lookingformydadscar
67-69 V8 Tech
Dec 3, 2008 06:57 PM
