aluminum heads for LT1
Old Feb 5, 2008 | 10:40 PM
red star's Avatar
Default aluminum heads for LT1
Ive been looking around at heads for my LT1, and have a few questions.
i was looking at AFR, with the 195cc heads would i have to change my intake manifold or would the stock one work. Would they fit an LT4 manifold. Also if i spend all this money on heads should i get all new springs and such or would the stock ones be OK.
(the part
http://www.airflowresearch.com/195sbc_lt4.php )
Old Feb 6, 2008 | 01:39 AM
95slvrZ28's Avatar
Default RE: aluminum heads for LT1
If you decide to go for the 195cc LT4 heads then you will have to change your manifold to the LT4 intake manifold, Edelbrock makes one that you can use. The LT4 intake's runners are raised 0.10" over the LT1 to allow for larger intake port volume as well as a better intake port angle into the cylinder. When you get the new heads you should get the complete head which should come with the whole valve train except the rockers, that way you know the vavle springs can get the larger valves down quick enough so you don't float a valve and screw up your motor. Make sure to note that the LT4 heads probably come with 7/16" rocker studs, so you will have to replace your rockers. Go for Comp Cams 1.6:1 roller rockers. You may have to modify your valve covers to fit the new rockers.
Old Feb 6, 2008 | 11:52 AM
LT1RUNNER's Avatar
ORIGINAL: 95slvrZ28
B-E-A-utiful!! Give that man a beer!!
Old Feb 6, 2008 | 05:23 PM
95slvrZ28's Avatar
[sm=icon_cheers.gif]
Always happy to help out!
Old Feb 7, 2008 | 03:18 PM
red star's Avatar
So, what other parts should i have if im going to do this. (heads, rockers and manifold) Would i need new vaulve covers or anything like that?
Old Feb 7, 2008 | 04:04 PM
95slvrZ28's Avatar
You won't need new valve covers, but you will have to modify the ones that you have. The new rockers are going to hit on the braces inside the vlave covers, all you have to do is cut one side out and you're fine. I recently posted a response to this very issue, I'll link it for you. The only other things that you need to remember are gaskets.
here ya go: https://camaroforums.com/m_156538/tm.htm
Old Feb 7, 2008 | 07:53 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
greg you never sease to amaze me if you get down from collage ill buy you a beer on redstars behave
Old Feb 7, 2008 | 11:11 PM
95slvrZ28's Avatar
It's Blake, but don't worry about it haha. And what can I say, I retain information well, this whole topic has been off the top of my head!
Old Feb 9, 2008 | 04:55 PM
red star's Avatar
I'm not going to have any issues with the hood closing am i?
Old Feb 11, 2008 | 01:37 AM
95slvrZ28's Avatar
Nope, everything is stock height. They even put the full factory LT4 into 100 1997 Special Edition SS's.
