305 v8, 4 barrel carb problem HELP
hey, im only 15 and i am still really learning about cars. i have an 87 z28 with a pretty much stock 305. when i fire the car up it idles really high at about 2000 or more rpm for a long time and then i have to slam the throttle to bring it down, it takes alot of slams to get it to normal idle. i only usually take it out of thegarage and let it idle for like 2 mins and it idels ok after i have it at the good idle speed. but the guy i got it from said when he took the car out for about an hour drive it would end up stalling. i dident really worry about that and it went out of my mind for the2 months ive had it now. so a couple days ago i gotta day liscence on it to take it to get the stereo put in, and after about 20 minz of driving, when we hit a stop light it would just barely stay alive and would juuuust about stall so my dad would have to put it in neutral and just keep reving it when we were stoped. and i couldent see it idleing at all after about an hour of drivving. then my uncle came over who knows a bit more about cars and he played around with the carb(carter afb competition series 4barrel). There was this little mechanism on the left side of the carb with aspring attached,he would fool around with and it only moved about 1 cm back and forth, he said it was part of the choke. and when he moved it around it would idel normally then go back to just about stalling. so if any1 took the time to read this and they have any idea whats wrong, or what i need to do, then please reply, thanks ( and by the way, when my uncle was fooling around with the carb, that was after i had driven it for 20 minz, therfore the problem was present)
THANKS.
THANKS.
