3.6V6DI engine parts not available yet!
Hi Guys
I have a 3.6V6DI engine that I am putting in a Replica mid engined race car chassis. (No waranty on this one!). What I need is a new intake manifold as the one that came on the engine was machined so there is a port miss-match (step) of .100" (2.5mm). Dealer says they are not released for sale yet - so can I purchase from the factory direct? Flow bench says the ports are large enough already so matching them by grinding would make matters worse - might even reduce size to increase velocity. ps. A spare set of heads to play with would be nice to! Thanks in advance Nigel |
Can you supply year / serial number or part number for Engine?
Engine Manufacture date was 23/04/09
with A90210847 by the hologram and 1A9100134 by starter motor VIN was 2G1FF1EVOA9100134. Hope this Helps Nigel |
| All times are GMT -5. The time now is 05:20 AM. |
