wax question
ok i clay bar the camaro today the waxed it. then it started to get dark, fast! i think i got all the wax off but im not sure? so i want to know if the wax being left on the paint is bad in any way for the paint? i know it will look dumb with missed spots but other then that? mothers clay bar kit is what i used.
RE: wax question
If you missed a spot just remove it. Not going to hurt anything.
RE: wax question
ORIGINAL: blackz87 If you missed a spot just remove it. Not going to hurt anything. |
RE: wax question
were you pretty happy with mothers clay bar?
RE: wax question
ORIGINAL: 2kcamaro were you pretty happy with mothers clay bar? |
RE: wax question
there is a place called Sam Brown, get the gray or blue compound. It'll work better than that stuff u get at murrays or csk or autozone or napa
RE: wax question
ORIGINAL: hevymetalg ok i clay bar the camaro today the waxed it. then it started to get dark, fast! i think i got all the wax off but im not sure? so i want to know if the wax being left on the paint is bad in any way for the paint? i know it will look dumb with missed spots but other then that? mothers clay bar kit is what i used. When the sun comes up, stand at the rear end of the car on one side and take a step away and look at the side at an angle. Crouch down so you are level with the car. Any wax remaining should stick out like a sore thumb. Do the same thing for both sides and the back/front end shouldn't be to hard. Most problems are little spots of wax left on the lower parts of doors etc. |
RE: wax question
I like Meguiars Smooth Surface Clay kit. $20
The white clay is easy to use and the kit includes a very nice microfiber towel. http://www.meguiarsdirect.com/imagesEdp/p84694b.jpg |
