clay not enought
it had been about a month since i waxed it
but i wash it atlest one a week . After the overspray i used the clay kit everystage worked great. The clay made the car feel real smoth but didnt seem to remover much of the overspray the wax remover on the other hand seemed to take allmost all of it off .....but i want all of it. so whould i clay it again the whole process over or should i get something differant..? |
RE: clay not enought
use kerosene. it will not damage your paint
First, where is the overspray on the car?
Depending on where it is (if it's not on a curved panel) you can always buff it with a wool pad, then use a foam pad, then you can wax it. Or you can wetsand w/ 2k grit nice and easy with some water then buff it out.
be really carefull if you go with the wetsand otherwise overspray will be the least of your worries
Ouch
