Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Rusty gas ank from ethenol gas additives
Old Jun 15, 2009 | 10:14 AM
maddog05's Avatar
Default Rusty gas ank from ethenol gas additives
How can I fix this rust problem short of replacement. Is there an additive to stop tank corrosion? Are others having similar problems? My fuel filter has to be replaced every 2000 miles; rust clogs it. When I replaced the pump I thought I got it all out. Seems to be fuel related since ethanol has been added to gasoline. Thanks
Maddog05.
1995 Z28 all bolt ons plus LT$ cam and modded heads.
Old Jun 15, 2009 | 11:40 AM
I have been running cars with 10% ethanol fuel for 10-15 years without any problems. Ethanol in higher concentrations is corrosive to various metals and seals and can cause leaks, unless the fuel system fas especially designed for it. However, ethanol does not cause rust. Rust in the gas tank is usually caused by moisture in the tank which condenses into water, usually due to habitually driving around with a low fuel level in the tank which leaves a lot of room for humid air to cause condensation. You may also want to check the fuel lines because if the tank is rusty, they probably have the same problems. The only good solution for a rusty tank is to replace it before it starts leaking and cause a fire.
Old Jun 15, 2009 | 05:51 PM
GRIFF's Avatar
I would suspect where you are getting your fuel from before i would suspect the ethanol. Ive pulled out alot of storage tanks over the years some are real clean while others are real ugly.
I would totally drain the system change the filter and try a another source.
Old Jun 16, 2009 | 10:36 AM
maddog05's Avatar
Thanks guys these are good ideas to pursue.
VALHAR
Dec 29, 2010 11:44 PM
hoppinchevy
Feb 14, 2010 10:34 AM
Spartan66
Feb 25, 2008 01:02 PM
odw777
Apr 16, 2006 11:13 PM
