Paying $25 via PayPal if help with this cars running. SES error 24 and 43
1989 Camaro 350 TBI T-5
Alright here's the deal. I am sick of this car, I cannot figure out what is wrong with it. If you give me an idea and it fixes the car I will send you 25 dollars over paypal. And I will trust me. Car runs fine until something happens. The SES light comes on. The car bogs down, when you WOT it gets VERY loud and the RPMs SLOWLY increase and barely can get over 3000 RPMs and SOMETIMES back fires in the intake. Shut the car down and restart it it runs perfect after that. I will be getting a video of this tomorrow. When I pull the codes I get 24 and 43. 24. When engine speed was between 1200 and 4400 RPM and throttle position angle was less than 3%, the MAP signal showed low voltage (high manifold vacuum) for at least 5 seconds. (http://www.austinthirdgen.org/index.php?pid=27#5LTBI) I just saw this and am unsure on how to fix this... Any ideas? 24. Circuit fault in vehicle speed sensor (http://www.thirdgen.org/service-engi...error-codes)My car does not have a Vehicle Speed Sensor 43 The ECM did not detect a knock signal during near wide open throttle operation with coolant temperature above 194° F or the knock signal was present for 4 seconds or more during normal engine operation. (http://www.austinthirdgen.org/index.php?pid=27#5LTBI) Replaced the Knock sensor 43. Low voltage at electronic spark timing circuit (http://www.thirdgen.org/service-engi...ht-error-codes) Replaced the ignition module What I have replaced on the car (was not meant to fix the problem): Alternator Battery Oil pressure sending unit ECM |
Does it only mess up at WOT or does it mess up at other times as well?
Originally Posted by 02StanGT
(Post 340247)
What if it was only just at WOT? |
Did you mean 305? The past two sites I have checked out say that in '89, the 350 only came with an automatic.
Make sure the Knock Sensor is good and screwed in tightly, and that the wiring between the Knock Sensor, ESC module, and ECM the is in good condition, and connections tight and clean. When the ECM sees a loss of the KS signal it will call for full spark retard, which will cause the engine to run like crap. IMO you should have replaced the ESC module rather than the Ignition Control Module.
