opti install
i finally recieved my new opti-spark today and i put it in. it wasn't that bad at all as long as u get the car good and high. everything went good as far as the install went. When i was done i took apart the old unit there was alot of water damage to the inside, the disks had been warped and there was a bent pin *the top pin* for the wiring harness. so i believe i found my problem with the car..
i will let you know tomorrow after the RTV dries. + pictures of the old opti. |
