Help Please!
Hello everyone, i am new to this forum. I have a 01 camaro with some starting issues, i have replaced the spark plugs and i have changed the fuel filter. i have fuel running all the way to the top of the injectors but the engine will turn over and not start, i tries to but it acts as though it doesn't have enough fuel in it. i can take a can of ether and spray it into the sir intake and the engine purrs. so i believe there is something wrong with the injectors, should i just get a new set of injectors or should i just get a cleaner kit? any suggestions are helpful
Thanks. The engine is also a V6 3.1L |
Check the fuel pressure and pressure regulator, and injector fuses.
Originally Posted by wellkyle
(Post 518486)
GM stopped putting the 3.1 in the Camaro in 1992. If you have a 2001 V6 the its a 3800. Should say 3800 right on the intake. |
Maybe he really has a 91, not an 01? ;)
