check engine light....help
check engine light is on and i need it off to sell to a dealer. My car is catless so I'm sure that's the code. Would a cheap tuner be able to get rid of it. Found this one on amazon let me know if this will let me eliminate the code. Thanks
http://www.amazon.com/Actron-CP9175-...842&sr=8-3 |
RE: check engine light....help
Even if you clear it with that, it will come back in after driving a littleif the 'problem' is still there...
It might work for you if you can clear the code right before you pull into the dealer. And then push the car onto their lot when they're not looking!
Or, you could take it to Auto Zone for a free scan to be sure of what the issue is. Did your light go on right after the car became "catless" (definitely related)? Or was it a while after? |
| All times are GMT -5. The time now is 09:05 AM. |
