Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
CFM question
Old Jul 2, 2010 | 10:25 PM
TG_69's Avatar
Default CFM question
I just installed an edelbrock performer 750 on my 402 big block. The engine is mildly modified with a new cam with an operating range of 1200-4600 rpm. The rear gears are 3:73:1. So did I over carb my engine? I haven't gotten it out and running the street yet, but if i give it a little gas I feel like the engine is flooded or something, granted I haven't adjusted timing or idle mixture and so forth. Any suggestions?
Old Jul 3, 2010 | 11:17 AM
No, it's not over carbed. The engine might just need a good tuning (initial timing, vacuum advance, carb). How come you went with only a 4600 rpm cam? A big block, and small block stroker motor already makes gobs of torque on the low end as it is. You could have extended the power band with a different cam, instead of having power start to drop off after 4600 rpm's.
Old Jul 3, 2010 | 11:41 PM
TG_69's Avatar
Default yeah..
I bought the car from a guy in SC and i thought the same thing when i read the cam card, but that's about all it has in regards to power. It's not bad really, I'd rather be rocking a hydraulic roller cam pushing higher rpm but I don't have enough experience yet to do a cam job.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
