Would this sub setup work.
Old Jul 23, 2011 | 05:50 PM
94ChevyCamaroV6's Avatar
Default Would this sub setup work.
Alright well I am thinking about getting a sub box for my 1994 chevy camaro v6. This box will hold 2 12s. I am thinking about these kicker subs along with a kenwood amp maybe. But for some reason I dont like the look of these kicker subs at all they kinda bug me for a wierd reason Idk If Its the color yellow or what but there Is a thing about them that makes me not want to buy them. I will post the links of the stuff below. But like on these two different amps one says class d mono amp the other says class ab bridgeable amp. Whats the difference. Will the kicker subs pound for bass because that what I want. I want a sub that will pound the bass. I havent had experience with subs before which means I dont want to blow any subs If you could point me In the right way with what stuff means or general Information about subs that I should know that would be great like about the ohms or the watt power etc. Or give any links to a better sub or amp or Information about Installing them that would be nice. One question that I did wonder about was how to sand the bolt for the ground wire. Will I Just take the nut off then sand the bottom then sand the metal that the nut would normally sit on then Im finished or what. Like what sand paper will I need. But will I also have to sand the o ring thats connected to the ground cable. Like If you know stuff about subs that I should know that would be great thanks for helping.
Kenwood - 1000W Class D Mono Amplifier with Low-Pass Crossover - KAC-8105D
Kenwood - 1000W Class AB Bridgeable 2-Channel Amplifier with Low-Pass Crossover - KAC-7205
http://www.bestbuy.com/site/Two+Kicker+Comp+12''+Subwoofers/9999142900050037.p?id=pcmprd142900050037&skuId=999 9142900050037
305_camaro
Aug 1, 2011 09:45 AM
sgtdupree
Mar 19, 2011 08:57 PM
80sbaby
82-92 V8 Tech
Jul 1, 2007 03:11 AM
badinfluenceRS
General Racing/Tech
Jan 23, 2007 03:40 PM
350rs
Aug 29, 2006 11:59 PM
