stereo help
Old 02-15-2008 | 05:33 PM
74Z28's Avatar
Default stereo help
hey guys, i just bought a sony deck and two 6x9 alpines for the rear. I have a few questions. First off, the place i bought it from said they didnt have a harness for the radio, so were do you guys find yours? Also They didnt have the antenna adapter. How do you make your antenna work with an aftermarket radio? Another thing, is there speakers up front?? What size are they? Also what size is an alternator and would I be able to run a 400 watt rms amp and not worry about electrical power issues?
Thanks guys
Old 02-17-2008 | 02:43 PM
sicked_wick's Avatar
Default RE: stereo help
ok damn...a lotta questions and i will try to tackle a few...its easier to know what your dealing with as in like what Generation of camaro but anyways. In harness do you mean the mounting harness in which you need to install in your dash prior to putting your aftermarket Head unit in. If you have a 3rd or 4th gen maro/firebird/TA etc. you can find these at wal-mart for about 15 bucks and will do the job just fine. If it is a 1st or 2nd gen you might have to custom order one from the internet. next, to make your antenna work you simply unplug your antenna wire from the back of your stock unit and plug it into the back of your new unit. as far as what your talking about with speakers i dont know because you didnt' specify the year of your car. and any stock alternator will be able to maintain constant power with a 400 watt amp... they're not that big.
Old 04-22-2008 | 09:49 PM
Skippysnax's Avatar
ya man the only other thing with that antenna is that u might need to buy an adaptor so that it will work with an aftermarket deck. Any electronics store should have them.
Gorn
05-17-2015 05:06 PM
01ss
10-01-2012 12:14 PM
Dana
08-24-2012 06:37 PM
Dappled Apple
10-26-2009 09:28 PM
jbf101
04-22-2008 09:56 PM
Quick Reply: stereo help
