Stereo color code with bose?
Help! My son has a 96 Camaro RS the previous owner or someone took out the Bose head unit but cut the wires instead of just unplugging them. My question is in each of the two speaker wire bundles there are four wires three colored and one bare where should each wire hook up. I did get a Scosche output converter but it's still all confusing.
The search feature is a awesome tool!
Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: Yellow Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2″ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: 6 1/2″ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Yellow Left Rear Speaker Negative Wire (-): Brown Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue |
I've been trying to find a diagram for how I can wire my Bose to an aftermarket stereo. I don't believe these color codes are accurate for the Bose system. There are no speaker wires. I've done some research on it and you have signal wires that go to the amp.
If anyone knows how to wire the Bose system to an aftermarket head unit I'd be grateful. Whoever had the car before me chopped off the harness so I don't have anything to work with. |
| All times are GMT -5. The time now is 09:05 AM. |
