Roadmaster sub tube install
Hey guys, ive got a roadmaster sub tube and a jensen amp i picked up from some friends for cheap along with some questions
1, Can i put these on the stock 6 speaker stereo 2, If so could someone throw me an infographic on how? 97 camaro rs with ac delco btw Thanks in advance guys |
You'll need an RCA adapter that converts the high level sinals out to your stock speakers to low leverl signals for your amp. You can tie it into your back R/L speaks and then run RCA's to your amp and you'll be set. Anything else?
well the backseat speakers are already amped mini subs are they not?
They shouldn't be, only the bose systems where amp'd, there are standard 6 speaker systems that are just normal speakers.
My car already has enough bass to shake things and the middle speakers only play bass frequencies, am I missing something?
Does your head unit say bose on it?
Nope, AC DELCO Theft loc II or something of that nature.
Then it should be just the normal system.
AC Delco = Chevy. Bose = Pontiac, iirc.
Im confused. I know i have six speakers and i know two only play bass.
| All times are GMT -5. The time now is 10:17 AM. |
