problem.
I cant see any thread in this section or alot of some others. Is there something i have to do to see the threads?
no,you should be able to see all threads signed in or not.
You may have to select how far back you want to see threads for. I usually go a month, but it's been a while since anyones posting anything in here so you may have to go father back. Or just do a search if there's something specific your looking for.
i cant see anything. i just need to know what all i need to instal my deck into my camaro. can anyone help?
you would need a install kit to take up the space, and harness adapter and antenna adapter and that's it. All that you can get at wal-mart or some other store like that.
For the harness adapter, you take that and hook up the wires from you headunit to it, then the harness adapter will just snap into the stock wiring. Should be about 20 bucks plus butt connectors or whatever connectors you use to do the connections on the adapter to the headunit. |
