ok, question
Old Oct 22, 2008 | 11:19 PM
irocktheIROC's Avatar
Default ok, question
im thinkin bout mounting my amp inside, and under my 2 12" solo baric l7s should i port it and put fans for my amp? also, should i stuff my capacitor in there too?
Old Oct 23, 2008 | 02:00 PM
RFxCamaro's Avatar
Default RE: ok, question
we need more info, what year, what size amp, do you mean to put the amp inside the box ??? or under the box in the t-top area, also i wouldnt think of adding fans to my amp inless its running a 1ohm thats when they can cut off.
Old Oct 23, 2008 | 09:16 PM
ok, my 89 RS, yes in the t-top area im turnin that into my box. 1200wts 2 channel. 4ohms.
Old Oct 25, 2008 | 06:59 AM
RFxCamaro's Avatar
ok i would bridge that amp at 4ohms mono for best performance, or get a 1ohm stable amp, when you get the box or make your own just get one with some space in between the box and rear end thats where i always put my amps
Old Oct 25, 2008 | 08:57 PM
kool kool, i wonder how the SPL will be in there with the L7s
Old Oct 26, 2008 | 12:19 AM
RFxCamaro's Avatar
you will love it trust me, i wish i had some l7s all i have are sum high end pioneers , by the way i was able to stuff a hc800 kinetik battery, 1.5 cap, a bd1000, 160.2 fosgate, and two huge pioneers in the t-top area
Old Oct 26, 2008 | 02:01 PM
oh yeahhhh[8D], its gonna be sick, my buddy has some regular 12" kicker comps in his 99, and For some reason they hit so hard you can barely breath, i just think the camaro is like perfect inside for bass reflex and stuff.
Old Oct 27, 2008 | 12:17 AM
RFxCamaro's Avatar
if your friend cant brethe he probably has asthma
Old Oct 27, 2008 | 03:42 PM
nahhh, its crazy how much air it pushes. first time i rode in it it was at like 15 (out of 32) and it blew my hat off my dome! lol
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
