LED hyperflash sometimes?
1 Attachment(s)
Hello all, I recently got tasked with installing the morimoto headlights and taillights on a 2017 SS and have been having some hyperflashing issues. The lights will blink normally for about two or three blinks then hyper flash. If I shut it off and turn the turn signal back on same thing, blink normally a couple times before hyperflashing until it turns off. Both the headlights and taillights come with pre-installed resistors that are plugged in, unplugging them has no change either. Hazards work normally however, as well as the brake lights and reverse lights. I've seen the LED harness for the non-rs models but there it says it only works for the factory housings. These lights were all plug and play but I don't know if it'll work. Any one have had a similar issue? I have attached a video to show what I'm talking about.
| All times are GMT -5. The time now is 03:22 AM. |
