flickering
Old 07-01-2008, 07:21 AM
RFxCamaro's Avatar
Default RE: flickering
get 4 guage wire, if you have 4 guage the all u need is to get a 6.0 cap der end of story you dont need a new battery
Old 07-23-2008, 12:22 AM
bigpunisher's Avatar
Caps dont really help that much. you need to just get a bigger alternator and maybe a second battery. I had the same problem in my car.
Old 07-23-2008, 06:44 PM
Camaro_Boi69's Avatar
1. get capacitor. (wat it does is store electricity that is not being used and helps when u turn it up)
2. Second battery. probaly be good to get a bigger alternater then.
3. if u do go with a second battery and bigger alternater u mise well gett the bigger wire because the bigger the wire the more electricty flows faster.
Old 07-25-2008, 08:47 AM
TRIPSxZ28's Avatar
Get a cap.... They work end of story.
Old 08-04-2008, 03:36 PM
Denhsturrr's Avatar
hey does anyone know if itll be alright to mount a second battery on the rear deck right behind the rear seat? im scared to drill through it since i might hit the gas tank or something else important
Old 08-12-2008, 06:57 AM
RFxCamaro's Avatar
first what kind of battry are you using, u should get a kinitik battery der bad ***, nd cheap on ebay i got a hc800 for $67 shipped,those come wid adapter so you can mount them anywhere without holes and dey dont leak
Old 09-23-2008, 08:10 PM
camaro76's Avatar
i used to have a big system in a blazer and had the same problem i solved it with a capacitor
RedFlame
12-19-2012 04:51 PM
rmoncur
LS Series Tech
12
02-09-2011 10:32 AM
neff75
05-19-2010 08:39 PM
scott14oh
11-01-2008 11:28 AM
JoeKramer
04-02-2008 02:16 AM
Quick Reply: flickering
