Antenna Options
Looking for good hidden antenna for my 69 or suggestions. Prefer not having a mast powered or not. Need advice based on use.
RE: Antenna Options
AutoLoc is what a few on one of the other forums I check out. I bought a hidden antenna from them with intentions on shaving the stock antenna. It worked when I tested it. Actually was not badsounding for me having it in the trunk. When I get it all said anddone with it will be mounted on the inside of the back window(which will be better than the trunk). I did have to get an adapter to get the antenna wire to connect with the stock one.
RE: Antenna Options
metra makes an amplified antenna that can be hidden behind the dash
RE: Antenna Options
Did the custom autosound amplified & even put a stock mast under the dash & they suck. Guess power antenna. Just hate to loose the smooth lines.
Thanks |
| All times are GMT -5. The time now is 06:25 AM. |
