2002 SS Stereo Upgrade ?'s
OK, I recently purchased a 2002 SS w/ T-tops. (have had it a week still smiling large)
I am going to be installing the following and wondered if you have any experience / success in the three questions below.
A) Where did you locate the GPS Antenna? (Looks & Function matter)
Thinking on corner of dash on passenger side
B) Where did you locate the XM Antenna? (Looks & Function matter)
Thinking rear deck/hatch, but have seen talk of success of spots inside vehicle. Anyone on Gen4?
C) Where did you tap into the reverse light circuit for Back-Up camera power / activation?
Camera will likely power at back of vehicle off light circuit. But activation for head unit needs that signal also, do I have to run a wire front to back to same location?
Head Unit: Kenwood DNX692
XM tuner: SXV300V1
Interface: PAC SWI-CP5
Camera: E-Sky - license plate mount (inexpensive one from Amazon- seen many good reviews)
Along with the standard, connection / splices, antenna adapter, dash trim adapter etc.
Vehicle is going to be my non-winter daily driver
XM tuner: SXV300V1
94V8jag
Apr 22, 2008 09:59 PM
