Tail housing leak th350
Old Mar 25, 2025 | 03:48 PM
Buchananr's Avatar
Default Tail housing leak th350
Hey guys. Haven't' been on the road since August and hope to get it running soon. 69 Camaro with a 350 and a TH350 trans.
Leaking from the transmission rear seal where the driveshaft enters the transmission. Should any fluid be in the tail housing? If not, other than replacing the tail housing to main body seal in the transmission, is there anything else I should check?
Also, how do you fill the trans with fluid without the fluid running out.? I know the air has to escape when filling it up, but is there some garage guy trick to keep it from running out when you're filling it up?
Thanks much
Buchananr
Getting Started
Mar 28, 2025 08:34 PM
L30/M20 RS
Jan 7, 2015 09:45 AM
98camarov6
Sep 23, 2012 07:59 PM
ScottD
Jan 4, 2009 09:45 AM
sewerrat
Dec 9, 2006 04:01 PM
