Tire and wheel size question
Will 265/35ZR18 tires (https://www.treaddepot.com/#!product...Fitment/252160) fit a 18x10.5 C5 Z06 wheel? Is there another size you'd recommend? Looking to get those Toyo Proxes T1's for my Z although I have to confirm the actual width of the wheel. (I believe they are either 9.5 or 10.5 wheels)
Thanks for the help! |
265 should fit fine on a 9.5 or 10.5. i have 245s on 8.5 which is the max acording to the shop and any other info i have seen. you can put 315s on 8.5 rims but the tire is tweeked so full tire contact is not made to pavement.
Originally Posted by craby
(Post 707440)
265 would be stretched. I would run a minimum of a 285 on a 10.5" wheel
agree, 10.5 rim would be right on the line. some 265s call for 9-10 and some say 9-10.5 rim. i would want to see them mounted to see how they looked.
