t-tops leaking help
anyone know where i can get t-top seal at for a good price without buying crap and are there any other problems with these cars that could cause the leaking?? my car is a 97 z28 with the lt1 5.7L
thanks for any help |
Mine leaks while driving and dumps on center console when you hit the brakes
Here's some brand new seals but there not cheap.
93-2002 Camaro / Firebird T-Top & Door Weatherstripping, New GM RH or LH - Hawks Third Generation |
Go to your local salvage yard and see what they price them at used. My buddy got 2 sets for $30 bucks for his 01. As not leaked since, and he as a spare(he got 2 in case 1 leaked).
The salvage yard dumped water on the camaro to see if they leaked be for selling, but doubt all will do this. That or dish out $300-400 bucks. P.S: I never take the t tops off mine, but then again i hate the look of camaro's with out them on. |
seriously $640 +shipping there just rubber not gold damn well i guess i have no choice
Originally Posted by mutlyi4
(Post 651514)
I had good results with mine after cleaning the seals and the tops well, then leaving them off on a hot sunny day, and letting the tops sit out in the sun as well, (underside facing up) and get hot. Then put them on while everything is hot from the sun. I think the seal actually reconforms slightly. My drivers side top leaked, and I was able to remedy it this way.
Are your seals torn up, or just not fitting tight to the tops?
Have you tried adjusting the latches yet to tighten them down more? |
latches seem to be to tight already i think and the seal are not ripped and they are still soft so im not sure what going on someone told me the drains might be clogged??
not sure where they are to try cleaning them though |
