Spacers or BFH?
So I got some Vette wheels for my Camaro and the are rubbing the inner fender. They are size 295 and Im thinking about just getting some spacers about a 1/4" thick. But if i do this i don't know if i will have to do something else to the lug nuts, so they will be able to get more threads. Does anyone know if using 1/4" spacers would work without any other modifications? And would if it would screw with the alignment or performance? Or any suggestions on a different solution.
Its for a 2002 Camaro SS. |
If BFH is an option, I'd go that way before risking safety/alignment/etc...
I'd rather go spacers that beat the crap out of my fender well, but that's just me.
If you go with longer wheel studs, it should be fine. I am pretty sure you can get either hub-centric or stud-centric spacers to ensure they align correctly. Edit: Here is a set for $150 at a local jobber: "Wheel Spacers" I'm sure they carry the longer studs too... (Edit) Comes with longer studs! :) |
| All times are GMT -5. The time now is 05:26 AM. |
