96 ss wheels
96 ss wheels
Hey All, wondering if anyone has put a set of Beyern Rapp wheels on their 4th gen. I've been looking forever to find something comparable to Fikse FM5's that is available in 17" or 18" and this seems to be the closest (reasonable) option, and I'm told has the same bolt pattern. Any info or ideas would be greatly appreciated.
Cheers
Cheers
Keep in mind that bolt pattern is only one of the specs the rim needs to meet. It needs the correct width, offset and center diameter to work correctly on a 4th gen. Manufacture should list applications it will work on.
Thanks for the reply Gorn. I am aware of what is needed to work correctly, just looking to see if anyone out there has done anything similar to this style of wheel or if anyone knows of a similar wheel available that will also work. I do appreciate your response though, and welcome all others.
Cheers
Cheers
