17x10 Torq Thust 2M
correction, been a few years so i looked at my order to make sure and the rear wheels are 17x11 with 7 7/8 back space front are 17x9.5 with 7 3/8 back space also note I have a 9 inch rear differential which is supposed to be stock width but may have a small variation. I did roll my wheel wells for the last wheel and tire setup so not sure if you will have to do the same. I will get a couple photos tomorrow. also the car is lowered about 3/4 inch.
did you look at the sticky at the top of this section? https://camaroforums.com/forum/93-02...s-specs-69936/
josh3408
Dec 10, 2010 10:29 AM
