02 Firebird/Trans Am fenders on 95 Camaro
I have a 1995 Camaro that I'm fixing up. I am not a fan of the blister of the upper rear part of the front fenders, or the really low set door mirrors. I have the door mirrors from an 02 Trans Am and I really like the way they sit up higher & out further that the Camaro mirrors. Does anyone here know if the Firebird/Trans Am fenders leading edge will fit with the Camaro's front bumper cover? Thanks in advance for any your help.
Nope, it won't line up, you'd need to put a firebird front end on it and that would look aweful. You can use the mirrors, but whatever mirror you use they will be in the exact same spot.
@ GreenArrow - White the mirrors from the Firebird do mount in the same exact spot on the Camaro physically, the Glass does sit up higher and further back/out, it also give a better image of whatever it behind, and lessens the blind spot.
