-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   wiring a tach (https://camaroforums.com/forum/93-02-v6-tech-14/wiring-tach-32291/)
camarofreak1990 Oct 14, 2008 08:17 PM
wiring a tach
ive got a tach, from sunpro, and ive got all the wired hooked up except the wire that controls the rpms, can anyone tell me which wire do i tap into in the computer?
bluovlh8er Oct 15, 2008 08:54 AM
RE: wiring a tach
neg. coil side, or tach signal wire... you can also tap into the computer somehow, but i chose the tach signal wire (more accurate....)
camarofreak1990 Oct 15, 2008 09:13 AM
RE: wiring a tach
yea ik i have to tap into tha tach signal wire, but which one is that? the paper that came with the tach says tap into pin id 8, its a white wire, i did that and it doesnt wrk.... idk....??????
bluovlh8er Oct 15, 2008 09:48 AM
RE: wiring a tach
on my 95 it was behind the passenger side kick panel under the glove box in plug c230 blue wire
camarofreak1990 Oct 15, 2008 12:05 PM
RE: wiring a tach
well the sheet that came with it tld me i have to hook it into the white wire pin id 8 thats coming from te PCM behind the passenger side strut tower
