wire routing
#21
RE: wire routing
The IAC controls idle speed, and won't cause misfires, but will cause improper idle speed & random stalling if the idle speed goes too low. IMO you should take a good look at the ignition system: coil pack, ignition control module under the coils, and the wires and plugs you just replaced, as one of them could be bad or improperly installed.
#22
RE: wire routing
the packs are good
the wires and plugs are good
i havent checked the ignition module cause its starts first try now that i changed the ECT sensor that controls the fuel
its starts on -5 degree weather first try
if the ICM was out wouldnt it even start right? cause it does.
it also sometimes idles high while im in drive y is that?
this car is actin a ***
ima end up buy this 90 camaro with a rebuilt 305 for $1800 but i didnt really want a older car
