window tint
Old 03-08-2011, 11:21 PM
carterbrad94's Avatar
Default window tint
what is the easyest way to take tent off the windows a straight blade an rubbing alcohol or what
Old 03-09-2011, 07:30 AM
3800camaro's Avatar
Stick your finger nail behind it to get it lifted off and then pull. Tint comes off fairly easy.
Old 03-09-2011, 01:58 PM
RFxCamaro's Avatar
3800camaro is correct if its tint from autozone, name brand tint like llumar and suntek will be stuck on hard. Best thing to do is to wrap it all in tin foil and heat it up in the sun or use a heat gun. Then use windex or any other amonia based product to scrape off with a razor blade.
Old 03-09-2011, 03:32 PM
nun of that worked
Old 03-09-2011, 04:01 PM
3800camaro's Avatar
Might be smoked glass then.
Old 03-09-2011, 04:06 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Take a steam cleaner and put it against the window. Thats how I got mine off. It worked very well.
Old 03-09-2011, 04:20 PM
Massey's Avatar
The glue that is used will be disolved using amonia or an amonia based cleaner. If the Windex with amonia didnt work try using straight amonia (with good ventilation of course) and spray it on and let it soak and then use a razor. It may take a few to get it to release. After that use a new razor and more of the amonia spray to get the rest of the glue off. This part is not fun and takes patience and time.
Massey
Old 03-09-2011, 04:58 PM
When I removed tint film from a previous Camaro, I peeled it right off in strips with no residue left behind. It was in the heat of the summer though, so if you're trying to do it outside in a cold climate, have fun with it.
Old 03-09-2011, 09:47 PM
i got it all off i have to use the razer to get it all off
Old 03-09-2011, 10:05 PM
3800camaro's Avatar
Why did you want to remove it anyways?
Quick Reply: window tint
