Well where did my coolant go??
there is a plastic elbow that fails. can you track a leak anywere, any puddles after setting? heres a thread that talks about the piece.
https://camaroforums.com/forum/93-02-v6-tech-14/losing-coolant-near-top-engine-3-8l-49527/
check the underside of the oil fill cap to see if theres some milky coolered slim there. is the oil ok, no water in oil? i had a problem like that and one of the hoses was leaking by the clamp, it was leaking so slow that it didnt show a puddle, had to get under there and move and pull/poke the hoses and found it.
O had my intake manifold repaired last year. It never had any puddles the only clue I hade was over the water pump it looked darker than the rest of the engine like it was slight wet. You should also check out the small heater hoses I had one section leak a fine mist and it took me forever to find
