Weird Shaking
If you have replaced the plugs, THE FIRST THING to check is the sparkplug wires. If one one crossed(not plugged to correct plug), it will cause the rough idle you're experiencing. I had the same thing happening after having some work done to mine. If that isn't the case, proceed with the other suggested solutions.
