Waterpump Replacement
Old Jan 11, 2010 | 02:18 PM
hawaiicamaroguy's Avatar
Default Waterpump Replacement
Heya!
I have 1997 Chevrolet Camaro Z28 Coupe.
Can anyone point out a good how-to for replacing a waterpump? I don't know anything about cars, but I'm on a tight budget, and friends/family are flaking, so I decided to tackle this on my own.
Any help would be appreciated. Thanks!
Zed
Last edited by hawaiicamaroguy; Jan 11, 2010 at 02:55 PM. Reason: did not post car details
Old Jan 11, 2010 | 02:25 PM
A little clarification first. You're posting this in the V6 section, but your signature is saying you have an LT1 Z28. Which one are you asking about?
Old Jan 11, 2010 | 02:44 PM
Autozone has a free online manual for jobs like this. 97 LT1? In the future you should aways post Car details so we do not have to guess if its the car in your sig or not.
Old Jan 11, 2010 | 02:54 PM
@Camaro 69 - Oh, man. I read that wrong. Jeez, first post on the forum and I post it in the wrong place. Sorry. Thought it said V8.
@Gorn - Alright, will do.
Old Jan 11, 2010 | 02:59 PM
Was there a question there, then?
Old Jan 11, 2010 | 03:53 PM
Oh, and there's a trick for replacing the LT1 water pump seal correctly, so you don't end up with an oil leak after you're done: https://camaroforums.com/forum/lt1-lt4-tech-9/installing-water-pump-drive-seal-43601/
Old Jan 11, 2010 | 06:35 PM
Alright! Thanks, guys! Tackling this job on the weekend.
Old Jan 21, 2010 | 06:58 PM
So my cousin (mechanic) and I replaced the waterpump and thermostat. The gaskets on the waterpump were all rotted and hence the leaking onto the serpentine belt. The thermostat was frozen closed, also. Just when we thought we had it, after 10-minutes of running the temp gauge shoots up. What was wrong? After tinkering around he found that the two fans weren't turning on. So what I now have to do is plug in a modified fuse so that the stronger fan turns on and unplug it when I get out from the car manually. Sometime this weekend we are going to install a switch so that I don't have to pop the hood everytime.
Norfolk96z28
Oct 19, 2012 08:07 AM
numskull223
Jun 28, 2012 07:01 PM
auto
May 16, 2012 10:24 AM
bbar
Mar 18, 2012 03:19 PM
VIPER RED 78
Jan 28, 2008 07:35 PM
