Vent problem
Vent problem
For some reason now the vents got stuck in the defroster/floor position, and it will not move, it makes a constant hissing sound that will go away with more gas put on the pedal, not when the RPMs are higher. Anyone have any idea what could be wrong?
RE: Vent problem
Its real strange, the vents always made an almost like hydrolic sound, and its like that sounds stuck on now and the vents refuse to change. It blows heat and all, but I gotta fix this problem before spring.
RE: Vent problem
The defrost/floor position is a default if something goes wrong. Like in your case. Maybe the problem is in the selector switch. I have seen a small pin on them break and it could leave the dial in there in a halfway spot.
RE: Vent problem
ORIGINAL: MadMikeZ28
RE: Vent problem
Start at the switch and look for where the hiss is coming from. If you hear the hiss you are getting your vacuum from the motor to inside the car. The vacuum would have to lead to the switch. Some where in between the fire wall and the switch there could be a break in the line. Maybe the seal in the switch is bad and is not holding the vacuum any more. Maybe the switch is broke and caught in the middle of two positions.
