V6 power adders?
Old Nov 28, 2011 | 02:50 PM
iLL95's Avatar
I Like to Party
Super Member
Originally Posted by Tommynasc
Thats a really good idea, when i bought the car it was already lowered. It also came with KYB gas struts installed which im pretty sure arent stock. I was told the struts wouldnt need to be replaced but the ride is so rough im thinking i should replace the springs/struts. I recently replaced the stabilizer links, tierod ends, upper and lower control arm bushings and it helped the ride but its still too rough.
Id also like to change the rear brakes from drums to discs. to do this do i have to replace the whole rear end? (which i guess il find from a junked ss/z28) or can i convert to discs without swapping out the rear end?
It would most likely be alot easier on your budget and time to just pick up a z28 rear and call it a day. I plan on making the swap when I get more cha-ching in.
Old Nov 28, 2011 | 03:12 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I still DD my car, see build thread in my signature and read through it.
Old Nov 28, 2011 | 03:19 PM
bill2129's Avatar
slow until you add boost
Old Nov 28, 2011 | 03:20 PM
iLL95's Avatar
I Like to Party
Super Member
^ Good helping post
Old Nov 28, 2011 | 03:40 PM
bill2129's Avatar
Originally Posted by iLL95
^ Good helping post
Thank's I try.
Old Nov 28, 2011 | 04:31 PM
Failed Devices's Avatar
if your car is lowered and doesnt have the proper shocks to match the lower ride height, it will ride like crap. You need to find out what springs it has and what the drop in height was. SLP Bilsteins will be your best bet more than likely, real good quality shock for the price.
Finish the exhaust with headers, high flow cat and y pipe and put on a SLP intake. Thats the extent i would go to for power adders, any more than that just really isn't practical for the v6. FI applications are difficult on these cars, no real turbo kits for them and those that are available (STS) will cost you more than a Z28. Doing a S/C is also difficult thanks to the engine placement.
Old Nov 28, 2011 | 05:24 PM
Tommynasc's Avatar
Can i just find the stock ride height and the difference from my current ride hight to get the spring height?
Old Nov 28, 2011 | 11:32 PM
Lilspleen's Avatar
BTW is your V6 still your DD?
yes it is, every day its driven rain, snow, or shine.
MaxTheKiing
Aug 23, 2010 03:21 AM
1979RS
70-81 V8 Tech
Feb 26, 2009 04:20 PM
bad98ss
Feb 24, 2008 12:04 PM
uncle bill
LS Series Tech
Oct 30, 2006 08:14 AM
