v6 to gen1 v8
Old 01-20-2009, 04:21 PM
mario82z28's Avatar
That's what I was wondering because I already have a fresh 350 block that needs put together but if there's going to be alot of other stuff involved I don't know if it'll be worth it, and the v6 specs hp are around 200 witch isn't to bad
Old 01-20-2009, 04:22 PM
SpecterGT260's Avatar
Ninja Administrator
actually, yeah. ur right. the carb has a tendancy to sit right where the metal cowl is..... they usually cut that
Old 01-20-2009, 04:25 PM
MusicMan's Avatar
The Jazz Man
That's why I said dual plane intake manifold. A short mani would minimize the cutting needed, but the distributor being on the back is just a pain. I don't even think you could use a carbed 350 without a cowl hood, which is ~$500 raw
Old 01-20-2009, 04:31 PM
mario82z28's Avatar
yeah I just spent 250 on getting a new stock hood and having it painted so I don't think I want to do that but I thank everyone for the advice, does anyone know if the supercharged 3800's will work say out of a gtp or a Bonneville
Old 01-20-2009, 04:35 PM
MusicMan's Avatar
The Jazz Man
The supercharger will not fit as it is, since the intake would be in the firewall. I have seen the S/C modified to fit, but it was very time consuming and difficult. You basically have to machine the back of it off and fabricate an elbow out of aluminum. The engine itself has lower compression pistons, and the heads are different since the injector bosses are in the head, rather than the manifold.
long story short, stick with an N/A engine.
Old 01-20-2009, 04:42 PM
Hey Musicman, I've been meaning to ask you what's with the smoke in your sig pic? Did you blow a head gasket?
Old 01-20-2009, 04:44 PM
MusicMan's Avatar
The Jazz Man
Naw. That was taken the other day, the first time it's been started since September. Just some moisture in the pipes.
mario82z28's Avatar
Do you have any suggestions on how to get a little more power out of the 3.8 then besides of course exhaust and cold air intake
Old 01-20-2009, 04:47 PM
MusicMan's Avatar
The Jazz Man
Exhaust and intake are obviously the best places to start. After that, I would say go for either an NA stage 1 intense racing cam, or an NA abbott heads cam. That'll add some fun to it.
  #20
Old 01-20-2009, 04:55 PM
swapping a v8 engine is not worth it all the labor and changes you will have to do
Quick Reply: v6 to gen1 v8
