Turn indicator malfunction
My left turn indicator stopped working this week. On the outside it no longer lights up, additionally, the left front yellow daylight running light is not working. Left front headlight works fine still. When I put on the indicator to the right, everything is fine, to the left it just is a solid arrow, no flashing and no left indicating lights... anyone know if this is an easy fix or something I need to take to a shop?
thanks!
thanks!
RE: Turn indicator malfunction
this is an easy fix, it happened on mine. the reason it is not working is because the bulb in the left front is broken and needs to be replaced. all you have to do is take the headlight off, and then take the bulb out of the bottom corner lense and replace it. you also might want to figure out what caused it to break, i had water leaking through the rubber gasket in my lense and it caused it to break many times.
