Turbo?
Old Jul 25, 2006 | 08:01 PM
CaMaRoDuDe's Avatar
Default Turbo?
Do ya'll think it would be okay if i put a turbo on my v6 camaro instead of a V8......i know the V8 would have more horse and everything.....i just don't want to spend the money for a v8.......How much Hp would the turbo give?Also whar brand.....do i have to have a certain one?
Old Jul 25, 2006 | 09:46 PM
02blackonblack's Avatar
Default RE: Turbo?
Depending on how many mods and how much psi you're pushing you could have more horses than a stock v8, it's all about the mods man. The problem with a turbo is that none exist for the 3800 camaro, one is in developement. The problem from what I've heard, is that the rear of the engine is very close to the firewall due to cab front positioning. Supercharger is the better solution. Anyways, if you're still interested in that turbo, here is a link to the only one I know of...
http://www.3800performance.com/Merch...roduct_Count=0
Old Jul 26, 2006 | 01:45 AM
94Z28SHAKER's Avatar
Default RE: Turbo?
check it out, if you or someone you know is good at welding and/or pipebending, you should go custom, theres a lot of info out there on the 3.8's just read up ALOT!
here is a link to an e-bay store that sells used/reman twin setups
http://cgi.ebay.com/ebaymotors/ws/eB...ME:B:FSEL:MT:1
you get the drift after seeing it.
and please if you go turbo Make sure you go with an intercooled setup, it will boost power about 1/3 compare to non intercooled.
or you could go all motor, wich is what i would recomend.
Old Jul 26, 2006 | 12:31 PM
CaMaRoDuDe's Avatar
Default RE: Turbo?
Mine is a 2.8 not a 3.8.
96V6Camaro
Oct 11, 2021 09:41 PM
Sixty7 Camaro
Apr 11, 2009 12:54 PM
