Tune-up
RE: Tune-up
It is also RECOMENDED that you change O2 sensors too. Best way to get to some of the spark plugs is from the bottom. I recomend Iridium plugs, but if you're just using it as a daily driver platnums will suffice. Take off the intake tube and clean out the throttle body, plate, bore, and throttle positioning sensors.
RE: Tune-up
You could add: new air filter, fuel filters, oil filter, oil change, PCV valve, grease the ball joints, change transmission fluid & filter, check rear end fluid level, check brake linings, check belts, and if you are really ambitious, change the brake fluid.
tedandangie
07-09-2008 12:06 AM
