trans flush
Old 02-21-2007, 11:07 PM
camaro girl's Avatar
Default trans flush
is it good to have the trans flushed? it was recommended at my last oil change. thanks for any replies
Old 02-21-2007, 11:42 PM
badinfluenceRS's Avatar
Default RE: trans flush
trans flush or trans fluid/filter change?
Old 02-21-2007, 11:47 PM
they said the fluid is not the right color. he said flushed? thanks for your reply
Old 02-22-2007, 12:04 AM
ok...not sure b/c all the fluid is not drained when you change the fluid/filter...
so yea...i'm not sure...hopefully a smart person will have that answer for you
Old 02-22-2007, 01:00 AM
The power flush is good because it gets all the fluid out, including out of the torque converter. The only thing I don't like about it, is that most places do not replace the filter.
Old 02-22-2007, 02:29 AM
MadMikeZ28's Avatar
They just push it to pay for thier expensive machines and thats right that they do not change the filter. It is to speed up thier process as well. If your fliud is really dark and burnt smelling then your screwed anyway. Once the fluid is changed it will start to slip afterwards.
Old 02-22-2007, 10:06 PM
shnormo's Avatar
That isn't exactly true ^. I do this for a living, and as far as I can say, I don't personally push for services one does not need. How much are they charging you? If your transmission is in good condition, it will be benificial to change it out. It'll give you better gas milage, smoother shifts, and it'll prolong the life of your transmission. How many miles do you have on you Camaro?
Old 02-22-2007, 10:27 PM
toml14's Avatar
I completely agree with shnormo. A trans flush can be very beneficial ...provided the transmission is in good working condition prior to the service. Do not attempt if the trans fluid is very dark/ bad odor/slipping. As far as not changing the filter goes, the only 100% way to go is have both done. It will cost more but is the best for the transmission. I have seen first hand the service go very well and not so well. 99% of the time they go well.
[/align]
Old 02-23-2007, 09:27 PM
if the trans fluid is not pink should this be done? its kind of brown i guess, thanks
Old 02-23-2007, 11:46 PM
i have about 76000 miles and i say $150 for flush and gaskets and filter
Quick Reply: trans flush
