tranny
RE: tranny
well...if you cant change your spark plugs then replacing a transmission yourself is out of the question for you
I've removed a transmission from a 80's delta 88 and it wasn't hard to remove, but then again I didn't reinstall one either
RE: tranny
Once you remove the rear crossmember the whole engine & tranny assembly will tilt back & everything becomes reachable. In order to get the tranny out the car will have to sit way up in the air (dangerous) or up on a lift. Get a good service manuals, as mostthings work better if done in the proper sequence.
