Timing Cover Gasket and Coolant Leak
Hello,
I have a coolant leak. A small one. I replaced the water pump and gasket and that didn't fix it. I believe it is comig from behind the pump where the pump connects to the timing cover and the timing cover connects to the timing cover gasket into the engine? I am curious if anyone else has had this problem and what I am in for to replace that gasket. I don't notice any coolant in the oil, just this tiny drip leak. I think the timing cover gasket is warn on the left side. It looks like fluid runs in and out of the engine on both sides through this gasket?
Any advice would be appreciated,
Sevenpelicans
Sevenpelicans
